Visual artifact or actual geometry?
Jlabs
Jlabs Posts: 28 ✭✭
edited September 2016 in Community Support
Im learning OnShape by recreating models I've previously made in Lightwave3d. Today I'm tackling a simple 6-sided dice model. It's one of the few models I've tried so far that is basically the same process in both apps: Intersect a sphere and a cube, fillet edges to smooth, make pips, profit. My problem is in onshape I've run into this:
Is this a rendering issue or has this actual geometry? My fillets did not fail and don't overlap, but they do come close to each other on all six sides. All sides are the same.
  • HI Jlabs,
    This looks like a graphical artifact, although it is hard to tell.  If you are willing to post a public link, this will allow us to look closer to make sure.
    Jake Ramsley
  • lougallo
    lougallo Posts: 2,020 image
    @Jlabs you can also submit a ticket and share with Onshape support if you are not wanting to make the document public... As @jakeramsley said, it is most likely an artifact.
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
