How to I hide mate connector that came in with a derived document?
OpenR2
OpenR2 OS Professional Posts: 188 ✭✭✭
So here I am. I thought everything was going to work. I put a lot of extra time in to try to just bully my way through this one...and I'm one click away from success and then a road block! Ugggg.
I derived a part studio with a mate connector. The mate connector is used to position the first clip spring. The I rotate two copies of it. I go back to hide the mate connector so I can have a clean look to the part studio before I release it....but I can hide the mat connector.
I tried going into the original document and hiding it but no luck in the derived feature.
its strange....color updates across the derived featue but not hide show?
  • OpenR2
    I just thought of workaround but it's a hack....
    1) hid the whole derived feature and make one more copy via roatation. But that leaves me wanting to take a shower! Lol. :)
    Any other suggestions?
  • OpenR2
    This worked as a workaround.
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    Currently there is no way to hide the mate connector on mobile. However, in the browser version, you could hide the mate connector by toggling the "eye" next to the derived feature in the featurelist.
    Onshape, Inc.
  • TimRice
    edited October 2016
    No, I am using the production version, take a took at the attached screenshot. I apologize if my previous answer was unclear!
    Onshape, Inc.
  • OpenR2
    edited October 2016
    Tim. I have no eyeball on any of my derived features. And no hide/show in the derived feature contextual RMB menu. I am confused.
    I do have eyeballs on features that don't directly contribute to the part or mesh. And then I have eyeballs on the part and mesh.
    I see eyeballs on the origin point, the three primary planes. sketches, and mate connectors.
  • OpenR2
    OK. I figured it out. The Derived feature must only get the eyeball if there is something more than a mesh in it? I was trying to select the derived features that didnt have anything but the mesh in it.
    So that's a little counter intuitive....can you explain when the derivative feature will have the show/no show contextual menu and when it wont?
  • OpenR2
    Thanks Neil.
    I am going to copy the document (project) and start by switch all the STLs to Y-Axis up and putting explicit mate connectors on them. And run back through constructing the space reservation assembly.
    Robert
