What is the equivalent of a surface trim in Onshape?
David_Parrott
Member Posts: 2 ✭
I am trying to transition into OnShape from Solidworks. As part of this transition, I'm recreating the hull of a sailboat design I've been working on. I've recreated the surfaces that define the form, and now I'm looking for a tool that is equivalent to that of a Surface Trim to create a watertight form. I can't seem to find it in the toolbar. Nor can I find it in the forum. I know it must be here somewhere, but I'm not that familiar yet with the interface.
2
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
You can use the split tool and then delete the excess faces (surfaces) that result: https://cad.onshape.com/help/#splitpart.htm?Highlight=split5
Twitter: @bradleysauln
Onshape, Inc.
@David_Parrott
FWIW, here are a couple other options you can try.
You might have luck extruding a rectangle and using replace face on the 3 faces that correspond to your surfs.
You can also create a rectangle larger than the surface faces but still within the surface bounds. Then use thicken on each surface to remove material. You could also use split, but then you would still have to do delete as a second step.
Split and delete is the only way, at least for now. Least, but not bad, for example, if you choose to split face, you can use even sketch to cut.
Here's a model that I've made sometime ago:
https://cad.onshape.com/documents/f38811dea54bd39b5e035437/w/4820f5aa90e5b90032d69a2c/e/dd0927f63e6394c3c076ccc4
It was done deliberately to test, if surface modeling is possible in Onshape... and maybe, but it forces you to compromise your design.
Offset Face: https://cad.onshape.com/documents/323312569b42b381b93ee95c/w/4feba228409d550cfecc4193/e/4f18ff5b4caf83cc9e65fee9
Enhanced Planes: https://cad.onshape.com/documents/0de04acb5bac92ca16796edf/w/cdd1d1882311084fe54bff24/e/680f0565e919e6e39a06f4df
Multi-plane: https://cad.onshape.com/documents/575857fae4b06a2590ec9d29/w/7a682d53abc1dbd6192f8299/e/be58c81aba88f5738dd746a5
3D Spline: https://cad.onshape.com/documents/573f7b36e4b02e83c71782fc/v/4e54a08374e12db1056f3bc2/e/5718da06c22e7b08a5fb58b3
While waiting for new surface tools, you still should be able to create your model in Onshape.
projektowanieproduktow.wordpress.com
