Error message "no part studios available" -- how to fix?
david_ayersdavid_ayers Member Posts: 3 PRO
I am trying to add a part from another part studio either to my current part studio (so that I can design to fit it) or at least to my assembly in that current part studio -- at least it would be a workaround.   It brings up Error message "no part studios available."  This is not true, I can bring up that part studio and see the parts that are available.  Who can help???  Thank you.
    @david_ayers You can use the derived feature and then use the Browse documents to pick the part studio you want to import.  If the part studio exists in the same document you can use the Current workspace area to browse.
Howdy, Stranger!
