How to move an object so that one face of the object snaps to another object's face?
florian_ford
florian_ford Member Posts: 54 ✭✭
edited October 2016 in Community Support
Hi guys,
Coming from SpaceClaim realm, I am so used to the "Up To" feature, where I move the "triade"'s center to a face of the to-be-moved object, then I hit the "Up To" button, then click on the "triade's" arrow corresponding to the axis I want to constrain the movement to and then I click the destination face and the object is moved "Up To" that face.
I am trying to replicate that behavior in OS but don't find it obvious at all. How can I achieve this?
I would also like to be able to "Ctrl+Drag Triade's Handle" to copy object. Is something similar available in OS?
  • Jlabs
    Jlabs Member Posts: 28 ✭✭
    I'm not sure if I'm approaching this problem correctly, but what I've done for the "move up to" problem is added a mate connector to both the part I want to move and to the destination face/part. Then you can do a 3d transform using mate connectors and they'll snap together. Occasionally I'll have to add a sketch here or there to correctly position the mate connectors.
    Another possible solution is to create a sketch construction line and use the "transform by line" type in the transform tool.
  • florian_ford
    This sounds pretty complicated. The way i achieved it was by measuring the distance to the destination face and moving, using the triad, by the exact distance. But this is not as easy as the way SpaceClaim does it...
  • Jlabs
    It's actually very simple. Click the point where you want the part to be moved, then add a mate connector. Second, click the point on the part you want to move and add a mate connector. Finally, choose the transform command and choose "transform by mate connector". You may have to flip or re-orient your mate connectors to get the alignment how you want it.
  • 3dcad
    @florian_ford
    Can you please open up your workflow a bit. I don't see a reason to move stuff around so much unless you have imported parts that you wan't to combine as single part.
    Assembly worspace is where you connect parts together if you haven't created them together in part studio. There mate connectors appear automatically and connecting two parts needs 4 mouse clicks to perform.
    For copying stuff you can use pattern or check copy option in transform dialog. But I don't recommend copying parts as you can use same part multiple times in assembly and keep editing easy.
    //rami
  • Curt_Welch
    Curt_Welch Member, csevp Posts: 43 PRO
    Mate connectors are powerful, but since the align all dimensions, they are of no help when only one dimenstion needs to be aligned.
    So say I have a pulley on a shaft, and I need to slide the pully right and and left along the shaft until one face of this pulley, lines up with a face of another pulley on another shaft. I don't want to move the first pulley to the other pully, I just want to align one face, with the face on the second face.
    The only way I know to do this in onshape, is ti create an entire sketch, based on the destination plane, and draw the location the first pulley needs to move to on the sketch, then use that as mate connection points.
    Or draw a sketch in the other plane, so I can create a single line that represents the move, then move by line.
    Having to create a sketch just to do "move to align" is a pain.
    If there were an option to move using mate connectors that included the power to align only on one dimension instead of all three, that could work.
    Is there a way to do that I don't know about?
    S1mon Member Posts: 4,613 PRO
    There's a planar mate.
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,268 PRO
    It sounds like you are talking about in a multi-part part studio? Pulley's are so simple and usually used across many unrelated projects, that they are the type of part modeled in their own part studio (or imported from a vendor).
    Would you be better off doing what you are asking in an assembly?
