Weldment in part studio
bill_daniels
Member Posts: 282 ✭✭✭
I am creating a fairly complicated weldment. To use this model in a FEA program, the part must be a single entity and not an assembly. I expected to accomplish this with Boolean joins in a part studio.
The weldment requires gussets which are at an angle to the three primary planes and the surfaces where the gussets join are cylinders which can't be used as a base for a sketch. If I could rotate a plane it would be simple to sketch and extrude the gusset or if I could sketch on a cylinder those would solve the issue. Alternatively, if I could use Boolean operands in an assembly, that would work too.
I can create a model of the gusset in another part studio and then copy and rotate to get the gusset in the right orientation. I hoped to use the Derive command to bring the gusset into the weldment part studio where it would be "welded" to the main part with a Boolean join. However, when I try Derived, I get this:
"A script on this page may be busy, or it may have stopped responding. You can stop the script now, open the script in the debugger, or let the script continue."
"Script: https://cad.onshape.com/js/jslib.50c38b80.js:3"
Whether I stop the script or not, OnShape locks up requiring the browser tab to be closed to proceed. I am running FireFox on Ubuntu LInux.
I seem to be blocked - any ideas?
twitter: @ken_welch | web: www.altair.com/simsolid
