Can OnShape convert a mesh file (STL) into a geometry file?
jingfu_liu
jingfu_liu Member Posts: 1 ✭
I have a STL file with >7000 triangle elements. Just wondering how to convert the mesh to geometry.
    NeilCooke Moderator, Onshape Employees Posts: 6,102 image
    Meshes can be imported into a Part Studio (may need preprocessing with STL Workbench from the Onshape App Store first), but they can only be used as reference geometry for building sketches etc.
  • ben_masefield
    ben_masefield Member, Developers Posts: 8 ✭
    Alternatively, you can use InStep (Connected Desktop App) to load STL/OBJ files and then upload to Onshape as a Document. That will give you a body to reference/interact with - but (obviously) it won't be parametric/feature based (but you can make holes/changes/etc. just like an imported Step file).
