Sketch Dimensions not visible
allen_bradley
Member Posts: 5 ✭
Onshape has been wonderful up until today. I have become totally dependent on it for drawing parts to be made on my 3D printer. Now, in sketch view, dimensions are no longer visible. Dimension lines are visible but not the numbers. This is true for drawings I am working on today as well as drawings I made weeks ago. I am using Linux Mint 17.3. I started learning Onshape using Firefox but it frequently crashed so I switched to Google Chrome. It worked well until 2-3 weeks ago when the dimensions disappeared. I switched back to Firefox and continued drawing. Two days ago it worked fine, today, neither browser will show me dimensions in sketch mode. Also the little isometric view cube in the upper right corner is gone. The red, green and blue axis lines are still visible but the cube labeled Top, Front, Right is not.
Any suggestions?
Any suggestions?
bruce_williams
Member, Developers Posts: 842 EDU
No specific info. but if you have not already, submit a 'ticket' through the Feedback tool Onshape folks are incredibly helpful. And they can often respond best if you send a screen shot and/or share document...www.accuratepattern.com5
https://forum.onshape.com/discussion/5288/dimensions-are-suddenly-missing#latest
