MY ONSHAPE ISSUES
Hi all,
i'm working with SW and got a call from OnShape , so i gave a try , redraw a existing SW model,
https://cad.onshape.com/documents/1c9c878bc7b9a7d7f81832a0/w/7f7adfca80b2bc9206d5c0f6/e/098a1655b0dbbcb863ff09dc
here is my issues:
Would be nice to include:
- External thread on a rod or shaft. Also external thread call out in drawings.
- Favorite materials. (it is a pain to go thru all material every time !)
- Drilled hole drill point angle change. (i know i can do sketch-extrude to make flat bottom hole, but than i need to wright depth in drawings.)
- Hole position require separate sketch ?
- Sketch line offset on both side.
- Base line dimension on drawing.
- Hole-shaft fit tolerance , precision.
- B.O.M !!
- Custom drawing sheet template.
- Hole table.
- Drawing shaded view .
- Auto balloon.
MUST INCLUDE :
- EQUATION DRIVEN DIMENSIONS IN SKETCH !!
- PART CONFIGURATION -PART CONFIGURATION - PART CONFIGURATION !!!!
this is after few hours of use.
All in all, it is a good program, for 3d modelling, (once u get use to the mates.)
Continue:
- CBore hole leave tapped/drilled option available ? Why ?
- When try to change sketch plane it is a disaster
here is my issues:
- B.O.M !!
- Hole table.
- Auto balloon.
MUST INCLUDE :
Continue:
Please vote on this Improvement Request if you haven't already:
https://forum.onshape.com/discussion/6857/external-cosmetic-thread
We can do this now
IR for AS/NZS 1100
