Modelize a screw or a bolt
lancelot
lancelot OS Professional Posts: 3 PRO
Hi, I try to designe a kind of a screw and the interior of a nud but I was wondering if my technique good? If you have ideas it will be great!
I used first an helix on my cylinder and then I sketched a triangle and remove matter with a sweep that follow the helix, but as you can see, the end is bad and I had to change the diameter of my cylinder to make it stop at the middle of it.
For the interior, actually the other part where this one goes in, I did the same.
Sorry about my english, I hope you understood.
