Having a problem bolting 2 flanges together..
Tony_C_
Member Posts: 280 PRO
I don't get what I'm doing wrong here.
I can't bolt this valve assembly together. The mates that should work just break the assembly when I apply them. Everything is cylindrical. I don't get why they're not going together.
https://cad.onshape.com/documents/0e3a2dbcc6a78822c324294b/w/92ede8d3a7af7de9095061ee/e/dd9055c2a74411e0d3cf8c79
I've left it where it begins to break. All I'm trying to do is put a cylinder mate on the bolt & nut........it doesn't like that.....and I can't figure out why.
I can make it work another way. I'm posting this to try and figure out why it's doing what it's doing when in my mind using a cylinder mate on a nut & bolt shouldn't break the assembly.
https://cad.onshape.com/documents/0e3a2dbcc6a78822c324294b/w/1a65d5ba680fa38db7888e0c/e/dd9055c2a74411e0d3cf8c79
eta: I think there may be something funny with the imported lock washer.
I think I found the problem. There's something wrong with the flange itself. The Center hub isn't concentric with the bolt pattern. I can put a mate on two holes and but trying to add in the center mate breaks it.
Thanks for looking into it though.
https://cad.onshape.com/documents/0e3a2dbcc6a78822c324294b/v/cb8292527e2c614293257522
The problem is with imported geometry. The bolt holes in 4"/FLANGE/SOC are cylindrical, however if you click on any of the round edges you cannot get a diameter measurement. This usually happens with files exported from certain systems. I deleted the holes and then recreated them to get the mates to work.
And I'm not shocked the problem turned out to be the flange. It's been imported and exported into 4 or 5 different cad programs.
I was just pulling my hair out trying to nail down the problem.
