Is there a way to reset the primary axes of an assembly?
trip_allen
Member Posts: 5 ✭✭
I built a complicated assembly around a part which was facing the wrong direction. Can I change the "front" and the other faces around now?
If you are in a part studio, you could use the Transform feature along with mate connectors to move the part. However, depending on how you modeled the assembly, you may run into broken references if you were to flip the part. If you can share a link to the document we could take a look.Tim Rice | User Experience | Support
Onshape, Inc.0 -
Hi, in a assembly you can reorientate your base part [and hence the parts constrained against it] by 1) select a face
2) move centre to a referance point, right click and select move to origin
3) left click on a axis and click align with z, finally you can use the three rotation handles to select the desired angle you want. Finally fix the point when you have the face you want on the front plane.
This is the way shown by onshape and works well once you get to gribs with it, to begin with i would simple use a fasten mate between the base part and the origin and align from there.
It would be nice to have a option in the view to make current view normal.
1 -
You can add it to another assembly correctly and stop using the errant one.
I find not having planes in an assembly confusing.
-insert your grounded parts 1st and fix'm
-add a mate connector to the origin 1st thing (Lou's hint) and build to it
Is this why things are backwards?
