Repeat parts in Assembly
seth_roskoseth_rosko Member Posts: 11 PRO
Hello! Thought someone here might be able to shine a light on something I'm missing.
I'm putting together an assembly which uses multiples of the same part placed in differrent orientations.
(Think of a ladder with cylindrical legs and T-joint crossbars)
The verticle bar/ coupler use a cylindrical mate, and I can place them as needed BUT I am unaware of how to call out distances between parts or how to mirror/ replicate sections that may repeat. There are over 70 instances of the same 2 parts, so I'd like to save time where I can. Admittedly I do not use assemblies in this fashion often so I may just be missing something simple. Any suggestions appreciated!
    You should be able to use the linear pattern command, even with multiple groups of parts or is there something else you're trying to achieve that I have missed?
  • seth_roskoseth_rosko Member Posts: 11 PRO
    Thanks Bruce, I think the issue here is I am using OnShape Mobile (on Ipad Pro) where this tool is not available.
