Can I print a 2D "JPEG" sketch on a paper printer
Hello All,
I am in the process of learnning how to use Onshape and CAD in general. Prior to discovering Onshape I was using SKETCHUP, i found sketchup to be too tedious in "fixing" the actual drawing" It took me half the time to make sketch in Onshape compared to SKETCHUP. Anyways one of the features that helped me in SKETCHUP was being able to print the 2D JPEG file that was the Actual size of drawing, that would enable me to compare the jpeg printout design to the mold.
Can anyone let me know if this is possible is ONshape.
Thanks
Regards
Thanks
Regards
I posted a possible solution there.
Print your drawing as a PDF, then import into the program in the link. Set the scale, and print out in 1:1 - automatically uses multiple pages if needed.
