Fillet corners in sheet metal issue
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 960 ✭✭✭✭✭
I am working with the sheet metal module and I came across one issue. The fillet command won't let me radius the corners on my sheet metal model. If I hit the finish sheet metal command then Onshape allows me to radius the corners but this does not propagate to the flat pattern. Am I doing something wrong here to enable fillet in the sheet metal work flow?
Thank you
Bryan Lagrange
Twitter: @BryanLAGdesign
