Some work around thoughts for sheet metal
bryan_lagrange
Member, User Group Leader Posts: 985 ✭✭✭✭✭
in General
Before Solid Edge had the etch command I would get geometry in model that needed to be in the flat pattern but not cutout by use the cut command and and only going about .01" deep. This would allow the model to flatten and show geometry that I wanted etched and not cutout.
When working with sheet metal in onshape you can only cut through the entire material thickness. You cannot just cut through a certain depth. Once you select completed sheet metal part you have the option to cut through to a certain depth but this will not show in the flat pattern (similar to adding fillets on corners).
One way would be to have the option to have a normal cut which cuts normal to the thickness and a regular cut. There are some instances that a sheet metal part will need features added by a mill or as I previously mentioned a laser etch.
6
Twitter: @onshapetricks & @babart1977
