Rectangle Tool - what construction geometry should Onshape provide?
andrew_troupandrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
edited April 2015 in Product Feedback
I was disappointed "back in the day" when Solidworks chose to add diagonal construction lines as an option. Of the three possibilities I can think of, it's the least useful.
One of the other two possibilities has recently been added to Sldwks (about a decade late, to my way of thinking): a full width construction line in conjunction with a full height one.
I would personally prefer (in most cases) a half-height line meeting a half-width one at the geometrical centre of the rectangle. I don't think I would ever have a use for the diagonal style.
The same options should be available for round-cornered rectangles when they put in an appearance (nudge, nudge !) and obround slots. I reckon. :smile:
  • aaron_digullaaaron_digulla Member Posts: 8
    I'm missing an "angle" tool where I can select two lines and specify the angle between them, for example when I need to put two columns near a corner and I want to place them at 22.5° and 90°-22.5° and a certain distance to the corner.
    @aaron_digulla  Just select dimension tool and select lines which are not in same angle and you will see angular dimensioning.
    //rami
    @3dcad Damn :smile: I'm still not 100% in the "Onshape has one tool for everything" mindset. Makes sense that the dimension tool can also measure/set angles. My guess is that this is triggered when the lines intersect? Or when they are not parallel?
    @aaron_digulla When they are not paraller, they don't need to intersect.
    //rami
    Ahem .... anyone have any thoughts on the question in the original post?
  • traveler_hauptmantraveler_hauptman Member, OS Professional, Mentor, Developers Posts: 419 PRO
    I have always used a single construction line on the midpoints of two opposite sides, using the midpoint of the construction line to center the rectangle. I don't feel the need for Onshape to provide any rectangle construction geometry, it takes me less than a couple seconds to add when I need it.
    It feels a bit odd though that I can use the center of a circle as a construction point but not the center of a rectangle.
    I understand that the center of a rectangle isn't a point that you clicked (unlike the circle) but the center of a line is also implicit.
    You can use center of a rectangle if you create rectangle by center point, not by two corners.
    //rami
