Chamfer transition two planes
I'm trying to finalize a part and have run into a scenario that is giving me problems. I've attached two screenshots, in the screenshot with red circle you can see the chamfer terminates and it's not pretty. I'd like to transition the chamfer around the whole that is on a feature that is at a different angle. I also attached a screenshot without the chamfer. I've played with trying to create surfaces that I could extrude to but haven't gotten the result I'm looking for (admittedly novice with surfacing). Any ideas? Thanx in advance.
https://cad.onshape.com/documents/06f3b613b2ef001e75a6687c/w/cc94c3dceffe5ce3fe0c89a3/e/d32726a64ee973243307853a
Not sure if this what you are after but by performing a split face and move I achieved this.
Twitter: @onshapetricks & @babart1977
