opExtrude with UP_TO_NEXT
emagdalenaC2i
Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
Hi
I am trying to simplify a FeatureScript using the UP_TO_NEXT option in opExtrude instead of BLIND, but it doesn't seem to work.
This is the part of code:
// Extruye el panel hasta la cara opuesta
opExtrude(context, id + "extrude1", {
"entities" : frameRegionToExtrude,
"direction" : framezDirection,
"endBound" : BoundingType.UP_TO_NEXT,
And this is the FeatureScript notices:
I am missing a parameter or anything else?
@opExtrude: EXTRUDE_UPTO_NEXT_NO_DIVISION
166:12 |
onshape/std/geomOperations.fs (opExtrude)
567:13 |
AluminiumProfile (const AluminiumProfile)
52:17 |
onshape/std/feature.fs (defineFeature)
605:21 |
Estructura (const buildPrivate)
608:13 |
27:17 |
onshape/std/partStudio.fs (definePartStudio)
17:12 |
Estructura (build)
7:12 |
Estructura (main) | |
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común
The error suggests that the code is fine, but the extrusion is failing in the part studio because the "next" body doesn't completely bound the extrusion (its projection doesn't cover the profile). I think for anything more specific as to why it's failing, we'd need to see the part studio and the code. Hope this helps.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
ok, thanks
It doesn't "completely" bound the extrusion
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0
