Planes perpendicular to splines and helix's
nic_tauroa
nic_tauroa Member Posts: 8
edited April 2015 in Community Support
I didn't want to start a support ticket for something that is already being worked on.
However is there any future for plans being made perpendicular to a splines (including 3d) end point?
Using a similar method currently used for line + point work plane generation?
I have made a work around for this for anyone struggling:
Draw your spline on one the work plane of your choice.
Create a line with a start point on the spline, make this line tangent to your spline and turn it into a construction line
Create a plane, select your construction line and the shared end point with the spline
Draw on your newly constructed plane, relation your constructed geometry to the end point of the spline, then sweep the geometry.
Director/Designer
Eva Mechanica Ltd
http://eva-mechanica.co.nz
6.PNG 110.3K
4.PNG 69.6K
3.PNG 38.1K
1.PNG 34.7K
  • nic_tauroa
    Thank you,
    I was trying this with a Helix and it did not work, I just assumed it was all Splines
    Director/Designer
    Eva Mechanica Ltd
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    Curve Point planes work with helices as well.  If it isn't, can you post an example?
    Jake Ramsley
  • nic_tauroa
    edited April 2015
    I just tried it now and it seems to be working as expected. I was certain this didnt work, i worked on it 2 days ago I would get a failed result, I tried several times hence why I came up with the method I showed.
    Thanks.
    Director/Designer
    Eva Mechanica Ltd
  • andrew_troup
    Thanks, both of you. Good stuff.
