Is it possible to modify a sketch offset once it has been created?
I am not taking about changing the offset value, but the collection of curves selected to offset.
Once the offset has been accepted/created, I cannot find a way to add to the selected set of curves involved in the offset. Is there some secret technique?
Note: I did discover it was possible to remove a curve's "offset" constraint which effectively removes it from the offset curve section set.
NeilCooke
Moderator, Onshape Employees Posts: 5,987
Sorry, no, because offset is not a feature. If it were editable it would need its own UI dialog within the sketch.Senior Director, Technical Services, EMEA5
As nice as it would be to have "feature" capability in the sketching context for Offset, Patterning, and possibly Mirror and Transform, I completely understand why it is not there, at least not yet; there are so many other more important things to focus on.
