Export 3DXML to step
ulf_rupprecht
ulf_rupprecht Member Posts: 1
Hi,
can onshape import 3dxml files?
I am looking for a possibility to convert 3dxml Files.
Ulf
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,095 PRO
    I tried and is says no
    NeilCooke Moderator, Onshape Employees Posts: 6,097 image
    No, sorry - 3DXML is a proprietary format from Dassault Systemes that nobody else uses.
  • joao_marmelo
    joao_marmelo Member Posts: 1
    Wrong, I just received RFQ from VW with a 3DXML File, not true nobody uses. VW uses even to be a very small automaker!
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    A 3DXML file is an XML file created in the proprietary Dassault Systemes 3DXML format. It contains meshes, textures, lighting effects, and other 3D object properties and is used to specify an XML-based 3D object.
    This is not a parametric part file, so ask for an industry standard 3D file.
    What I meant was nobody other than Dassault Systemes uses this as a format - or in other words - it is proprietary to them only and not an industry standard.
