How to keep an openBoM BOM sorted in Onshape Drawing
oleg_shilovitskyoleg_shilovitsky Member, Developers Posts: 131 PRO
The latest openBoM update allows to sort BOM in Onshape drawing by Balloon number
You can get details here.
https://medium.com/@openbom/how-to-keep-an-openbom-bom-sorted-in-onshape-drawing-33c9eb8be603#.u3yjell52
  • jackson_kingjackson_king OS Professional Posts: 80 PRO
    Nice work openBoM team!
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    Just working out how to get a OpenBoM into a drawing. The video on the link above was helpful to get the columns in the right positions.
    I am wondering now if I can change Quantity to Qty.  and Balloon Number to Number or No. ? This would reduce the width of the columns with only small numbers in them to save space. Also help as the table resizes when doing an update in the drawing
  • oleg_shilovitskyoleg_shilovitsky Member, Developers Posts: 131 PRO
    edited March 2017
    @brucebartlett
    Unfortunately, you cannot rename these properties in current versions, because of the way we hardcoded them in Onshape openBOM template. But we are aware about the problem of property customization. We are working to provide user defined templates to support customization of Onshape BOM and we would considering to support alias to property there (today it is supported for regular openBoM properties). A possible workaround is to change property names already in Onshape for the moment.  Sorry about this limitation for the moment.
    Best, Oleg
    Oleg,
    Is there a way to get the new properties into your an existing OpenBoM now included in the Onshape Doc, ie Vendor, Titles 1,2 &3 ?
    @brucebartlett
    Not for the moment. It will come in April with the next openBoM production update.
    Thanks, I will wait till then. Looking forward to it.
    @brucebartlett
    Best, Oleg
    @brucebartlett
    It is possible now to rename all properties in OpenBOM and they will come to Onshape renamed.
    Thank @oleg_shilovitsky I'll try that out
