Sub assembly mate overconstrained
pierre_gilles
Member, Developers Posts: 7 ✭✭
Hi everyone,
So I have started to model the DBOT Core XY 3d Printer designed by spauda01 (http://www.thingiverse.com/thing:1001065) on OnShape.
My 2 goals are to learn to use Onshape, and to have a 3d model of this printer so I can easily make some improvement once I had built it.
My issue is in assembly. I have a first assembly "3x3 Plate Rear Right Assembly" composed of 12 parts. 1 plate and 11 screw and nut and washer.
I ha ve used the fastened mate to assemble the fasteners with the plate. Everything is fine.
But when I use this assembly in another assembly "Rear right Beam" The mates of the sub-assembly are displayed as overconstrained. even if I did'nt add any constrain in the assembly.
Here are 2 pictures of the feature tree of each assembly
Rear Right Beam (assembly)
I don't understand what I am doing wrong. Any help would be good.
Here is the link to the document which is public https://cad.onshape.com/documents/2096e13f381fdeed3052900f/w/6b4f89df6b2af6490fa259ee/e/0ac1e9b27da914a904790a50
3x3 Plate Rear Right assembly (sub-assembly)
Looks like it has something to do with your pattern.
I couldn't get it to it work until I deleted the pattern and inserted the fasteners manually in the 3x3 Plate Right Rear Assembly
https://cad.onshape.com/documents/58d1d05ff39e860f8ed2984f/w/9dfbbcbf106681dfaa1e8caa/e/f1d95272f16113476a38b86c
This may be a bug, I had a similar thing happen a few weeks ago and put in a ticket. It eventually fixed it's self actually but I'm not sure what caused it.
By the way, you are planar mate crazy
5
5 -
Ok, I'll try to avoid the use of pattern for now.
Yep, in fact it's a solidworks habits, I understood how to use mate in onshape once I had made a lot of assemblies. I am in the phase of recreating the mates in a more "onshape" way.john_mcclary said:By the way, you are planar mate crazy
Thanks for your help !!0 -
This is a bug. Will be fixed soon. Thanks for bringing it to our attention.0
