Featurescript - query/delete all sketches
leon_poot
Member, Developers Posts: 87 ✭✭✭
I want to clean up my Part Studio, so that when I derive it in another (using opMergeContexts in FeatureScript) I don't get all the sketches and points and all, but I do want to import all parts and surfaces at once.
Either I can query these one by one, calling opDeleteBodies on all the queries, but I'd really like a smoother version where I don't select these by hand, but automatically query them.
Can anybody point me in the right direction for querying all sketches at once?
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless
@NeilCooke It would still leave behind sheet bodies created by sketch. One can use
evOwnerSketchPlane() to filter for sketch objects, but in next release there'll be qSketchFilter() making it easier.
5
In the next release, we expect to have a convenient query filter for sketches. Currently, I'm not aware of a way to avoid querying for the sketches one by one by id.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Would qBodyType work using WIRE?Senior Director, Technical Services, EMEA0
5 -
Filtering a query (all WIRE and SHEET bodies, and VERTEX entities) using evOwnerSketchPlane() works excellent. Thanks.
var qAllSketchEntities = qUnion(filter(evaluateQuery(context, qUnion([qBodyType(qEverything(), BodyType.WIRE), qBodyType(qEverything(), BodyType.SHEET), qEverything(EntityType.VERTEX)])), function(entity) { if (try silent(evOwnerSketchPlane(context, { "entity" : entity })) != undefined) return true; else return false; }));"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless0 -
I simplified your code to this:
var qAllSketchEntities = qUnion(filter(evaluateQuery(context, qEverything()), function(entity) { return (try silent(evOwnerSketchPlane(context, { "entity" : entity })) != undefined); }));It gives a different number of bodies in the result, don't know why, but it works.
Edit: although using the profiler I see yours is faster due to not testing solid bodies.Senior Director, Technical Services, EMEA0 -
Setting it to qEverything(EntityType.BODY) picks up all sketch bodies and makes the code 3x faster too!Senior Director, Technical Services, EMEA0
Thanks @NeilCooke That makes perfect sense.
I tend to think of only solids when I see "BODY", so I took some unnecessary detours in my code without thinking."A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless0
