Is there no way to import a STP into an active studio?
in General
I've researched through the threads with some detail and have not stumbled across a solution.
- You can import into separate studio and derive parts to existing studio (check help for positioning)
- Import first and continue modeling into same studio
If you think importing to existing part studio should be possible, use feedback to share your need with Onshape - there might be others and someday such functionality might be available.
