Help with Mates and making a V shape with tube not having them parallel
don_short
Member Posts: 2 ✭✭
Hi
I am trying to draw this simple motorcycle frame but an struggling with the mates to connect the front to the rear of the bike with some tube. I have tired different things.
When I connect the second tube it automatically wants to make it parallel with the first and I would like it tapered
If you have the time look at revision 1 and you will see what I mean.
I am sure there is a simple solution I just can not work it out at the moment.
https://cad.onshape.com/documents/4e077b44d37043421cb3cc66/w/ab278644fcea7b2819536d51/e/5d3f34e37c8d88d53bf6e83d
https://cad.onshape.com/documents/58e2dce71b7aa90f817478d1/w/12a8dd01116e4242e5a9dc4d/e/f3fa2641168182a4f7a48db7
use a ball mate instead of fastened, it has more degrees of freedom
5 -
yep,
sorry forgot to make the linked document public
try this
don't forget to remove your previous fastened mate5
5 -
Do I need to try a ball mate at both ends?0
yep,
try this
