Using Z axis of mate connector error once transformed
Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭✭
Hello, I am working on a feature that imports a part with a mate connector. I am then rotating that part using the mate connectors Z axis. I also have a boolean which if true, it will rotate about the mate connectors X axis first. The error occurs when I then want to rotate about the mate connectors Z axis. I would think the mate connectors local Z axis would now be perpendicular to the global Z axis. But it is parallel i.e. the part has rotated, but the mate connector hasn't. What is peculiar is it looks like it has in the part studio, but debugging reveals it is (0,0,-1), not (0,1,0). Why is this?
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • Options
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,417
    You also need to transform the mate connector.
    Senior Director, Technical Services, EMEAI
  • Options
    The problem is that I am using that mate connector to call line() for use as the axis. I have called evMateConnector(). If I use the evaluation in opTransform(), it throws an error. By the picture I posted, hasn't it already been transformed?
    Document:https://cad.onshape.com/documents/6ca70d535fb4f9822b343214/w/028f50d7a2a757243c7bcc3d/e/8fd9a3be9e398d391a60eda5
  • Options
    I fixed it, I had to call evMateConnector() after the initial transform.
