Fillet multiple vertices broken?
jack_heizer
Member Posts: 4 ✭
I can't for the life of me fillet a bunch of vertices with the same radius so that changing one radius changes all of them. I'll select the fillet tool, select the vertex, enter the radius, press enter, and (with the fillet tool still selected) select the next vertex. At this point it will create a new fillet with a radius unrelated to the previous one. The worst part is in the same sketch I was able to do this, I just can't get it to work again.
Am I doing something wrong?
I've noticed sometimes the tool will create an unrelated fillet from time to time.
Is it doing it to every fillet? Or just a few at a time?
When it happens you can select all of the fillets that have their own dimensions, then add an "Equal" constraint, then delete the extra dimensions.
I don't know the real cause, but I think it has to do with working in a web browser. There is noticeable input lag all over the place. I've really had to calm down my click rate for it to keep up
But when it works, It works well, so I can't complain
It happens so often I make a quick video and it did it 4 times
https://www.youtube.com/watch?v=0gqEbSSkAN0&feature=youtu.be
