How to make this gearing rotate properly
konstantin_shiriazdanovkonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭
edited April 2017 in Using Onshape
I created a gearing with intermediate rolling elements, but can't make all the rollers move properly because pin slot mates (that should make rollers move in the slots of separator) starting randomly flip direction by 90 deg, when i'm starting to rotate output shaft
https://cad.onshape.com/documents/5b127d8c24b2f4fe30160ab3/w/a4007bd59e449c044bc650ae/e/d39c27f81560c534939f963f
this video shows how it really works, though it is in russian
https://www.youtube.com/watch?v=fAamyym1XCk
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    edited April 2017
    https://cad.onshape.com/documents/58fe0d482e4c331084893352/w/ca82f7104e8c8d107ed96cf6/e/6299877fe50016435e5b8a54
    It's not perfect, but you may have to look into the profile on the outer ring.
    The top roller bearing stays seated while others show gaps.
    If you follow my mouse cursor you can see what I mean, it lines up perfect on one side but not the opposite side
    https://www.youtube.com/watch?v=FeVg7sP3wVk&feature=youtu.be
    Also don't forget the intermediate ball bearing between the cam and the outer roller bearings :wink:
    edited April 2017
    thanks, @john_mcclary, looks like this gearing isn't as simple for motion exploration as I thought. if to add two tangent mates to the slot of separator and to the eccentric for each roller it shows the correct motion, but tooo slow
    Side note: Try not to use a tangent mate unless it is a last resort. As you have seen they are very un-reliable. That goes for any CAD I've used.. They like to flip out sometimes :)
    I'm willing to bet you will need to size your bearing's circumference (B) to be proportional to the surface length of (A) in relation to (C).
    But this is over my head :(
    I just buy these gearboxes, not make them :)
    edited April 2017
    @john_mcclary if you're referring to slippage and friction of roller to the eccentric in my simlifyed constructon you are right - in the original video they use one additional bearing on the eccentric shaft to reduce that effects.
    About tangent mates - I just have to use them to make sure all the rollers are in contact with three part at a time
