CAN'T RADIAL DIMENSION ON SECTIOANAL VIEW
michael_mcewenmichael_mcewen OS Professional Posts: 78 PRO
Any one have a clue how to place a radius dimension on a sectional view within a sketch.  Seems as though all the dimension tools work on the section except radial dimension??
  • michael_mcewenmichael_mcewen OS Professional Posts: 78 PRO
    I meant within a drawing . . .
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Hi @michael_mcewen - is your radius normal to the view? If it is slightly off then it will be a spline. Can you share an example?
