How To fill space with solid from outer circle to existing honeycombs?
kev_keegkev_keeg Member Posts: 9 ✭✭
On the part called "Roller" in my area, I need to fill the space between the honeycomb and the outer circle with solid, WITHOUT filling the small spaced between the embedded cones in each honeycomb with solid. How may I do that? If it were NX, I would extrude the outline (outer edge) of the honeycomb.
Thank you.
    Hi @kev_keeg can you share your example (doc URL plus images to explain)? Can you not just replicate the process you use in NX?
    Kev - just to be clear, employees cannot see your documents unless you make them public or explicitly share with support :)
    Philip Thomas - Onshape
