Reverse Direction of Curve Pattern
I can't figure out how to reverse the direction of this curve pattern
I need 1 part in the direction shown (lower clockwise), and one part in the opposite direction (higher counterclockwise).
But both helix curves put the part lower clockwise.
If I then hide part<1> and pattern part<2> using the same curve; it then makes a new part in the same position as part<1>
How can I control the direction of the pattern?
How come there isn't an option to flip the direction along the curve :p
Thanks
https://cad.onshape.com/documents/28050bca2b1ddeb0acbab720/w/72369ffa7faabbf84de28ab1/e/c327eb1c365e08ad62fdd2dd
