Loft Guides: Is a Guide Spline Required For Each Vertex
cory_ibanezcory_ibanez Member Posts: 10
As stated in the title, I am trying to loft between two faces that each have 4 vertices. I want to guide this loft but if I try to guide it using only one vertex, the loft has self intersecting segments and I get an error. Is there a way to have only one guide that guides the entire loft using only one guide spline?
    Have you tried the new loft with path?
  • cory_ibanezcory_ibanez Member Posts: 10
    I have not yet, I didn't even know it existed I will try this out
    The new loft with path did exactly what I wanted! Fantastic thanks Neil
