Drawing plane
ptscad_ptscadptscad_ptscad Member Posts: 5 PRO
How to create drawing plane on curve surface?
    Sorry, you can't.
    HWM-Water Ltd
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    The plane does not have to be on the surface. It can be in front or behind it. Can you use a default plane? Otherwise you may need to create some sketch construction geometry so you can use it to position your plane using a method such as curve point.
