Determine which options were selected when previously using a feature to create a part?
ENG_1
ENG_1 Member Posts: 4 ✭
Is there a way to access a piece of information that was input by selecting an enum value to create a feature, the next time that feature is used?
For instance, if I made a feature to create cube with an enum option for filleted edges, would it be possible to then use featurescript to query that cube and determine whether or not the user chose to have filleted edges?
  • lemon1324
    lemon1324 Member, Developers Posts: 230 EDU
    In this application, I think the attributes would suit you better, as they are associated to geometry and not global.
    Say, for instance, you make two cube features, one of which has the fillet option and one which doesn't.  Using attributes lets you respond to both of these in later features independently, rather than overwriting the Variable (which is necessarily a global variable).
    Arul Suresh
  • konstantin_shiriazdanov
    @lemon1324 from this point of view you are right
    Or do you just want the next feature created to use the same inputs selected last time? In that case just use "UIHint" : "REMEMBER_PREVIOUS_VALUE"
  • ENG_1
    Thank you @lemon1324 and @konstantin_shiriazdanov, I believe these are exactly what I was looking for. I think that there might actually be a use for both global variables and attributes in my specific case.
  • kevin_o_toole_1
    I agree that Attributes are the tool for the job: One custom feature can set attributes that another can read. Here's a feature with examples as getting and setting attributes (which simply gets the attribute value and prints it to the console):
    https://cad.onshape.com/documents/5de745b789701c60bf75fd19/w/3d4893fbd20b641cfbce25c9/e/71100f5de8e6955281228275
