remove extrusion uppon 3D fit spline curve
iulian_manoleiulian_manole Member, Developers Posts: 2 ✭✭
Hello,
I cannot find a proper way to remove the extrusion uppon 3D fit spline curve. I would like to remove the circle surface, following the selected path. Might I'm not doing correctly, is there any other approach?
How to do it?
https://cad.onshape.com/documents/c27afb3f4ab29e82024058b9/w/1655c76bb901a4b9c7f41ffa/e/f20ef07fd5d91fc4e92ca18e
Thank you
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,925 image
    Have you tried using sweep?
  • iulian_manoleiulian_manole Member, Developers Posts: 2 ✭✭
    edited August 2017
    Basically, I would like to know how I can remove the extruded circle following the 3d fit spline and rotate the extrusion upon vertical axis. Sweep is not follow exactly the rotation surface over the Part1 surface. Maybe there is other approach, but I don't know how to do it, or maybe the 3d fit spline is not suitable for this matter.
    Thanks,
