scale, rotate, move, move and copy
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 960 ✭✭✭✭✭
I have been using the transform command to rotate, move, move and copy sketch entities. In my opinion it could be made better.
This is what I propose:
Select an entity and select transform command. There you could choose from a list what you would like to do (rotate, scale, move)
Rotate: you select the entity, dialog box you choose you want to rotate, select the point on the entity you want to rotate from, enter degree of rotation,choose if you want to copy or not.
Move: you select the entity, dialog box you choose you want to move, select the point on the entity you want to move from, enter x and y coordinates, choose if you want to copy or not.
Scale: you select the entity, dialog box you choose you want to scale, select the point on the entity you want to scale from, enter scale factor, choose if you want to copy or not.
You could later add functionality such as non uniform scale,etc. but these basic steps in my opinion would make a better transform command.
Bryan Lagrange
Twitter: @BryanLAGdesign
    Improved sketch transformation tool would be very useful. One addition I would include is the ability to move by selecting references (for example, I'd like to select a point on my sketch entity, then select a destination point).
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,953 image
    @tim_hess427 - you can drag the origin of the manipulator and then snap to other geometry if that helps. If it is a point on the model you may have to create a sketch point and add a coincident constraint first.
    https://www.youtube.com/watch?v=blw4bC82_sg
    @NeilCooke - Thanks! I was trying to do that exact thing, but I guess I just didn't get it lined up close enough to snap to the origin. I'll give it another shot.
