Strange conversions
I use Onshape for developing 3D-models and 2D objects to produce files for a lasercutter. For the last I export objects in a Part Studio as DXF files - version 2000. I open the files in Autocad 2016 to change the linecolors into blue (for cutting) and red (for engraving). And save the file. The lasercutter uses Coreldraw, so I open the colored file in Coreldraw, and start the cutting process. (It's a pitty that Onshape has no colorfeatures for hairlines).
There are two issues:
  • Circles in Onshape are also circles in Autocad 2016. But what is round in Onshape is more a polygon in Autocad.
  • Combinations of circles or bows with connected lines are in Onshape and Autocad the same (uh ... more or less polygons). But when I open the file in Coreldraw the circles or bows are not longer connected. e.g. not printable.
Gr, Hans
