How do I rotate a sketch 90 degrees?
jim_thompson
Member Posts: 7 ✭
I started my sketch in the front view. My 3D printer software needs the part in the top view. How do I rotate my part 90 degrees so it appears properly in the Top View?
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
@jim_thompson
You can simply change the plane for your sketch. To do this, go to edit your sketch and delete front plane; then click top plane instead.
//rami4
