Clean Common Parts with export to parasolid then import back again - Worth it?
Hi folks.
Toying with the idea of exporting my "set in stone" revisions of library parts to parasolid then back into OS again to create clean and faster loading files. Especially where I've not modeled them sensibly, say with a chain of derives or direct edit.
Cons:- Loss of history, but if edits are required the source partstudio still exists.
Any thoughts on whether it's worth it?
Cheers, Owen S.
Cheers, Owen S.
HWM-Water Ltd
HWM-Water Ltd
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,147 PRO
I think its the way to go. Direct editing is heaps quicker in a lot of cases than tracing back through a tree with heaps of edits and dependencies, studios can get very slow once up to the 100 or so features. I'd like to see a compassion of load speeds of a complex part into an assembly for the clean imported part as opposed to the messy studio part but the same finish geometry.
The biggest con I can see is if you have drawings and assemblies all links will be lost.5
Twitter: @onshapetricks & @babart1977
Owen S.
HWM-Water Ltd
I thought I read in some other post that when you link to a versioned part in another document that Onshape caches the geometry of the part, which should be similar in speed to an imported dumb solid. Plus, if you just use a link, you retain the ability to edit the part features more easily.
Owen S.
HWM-Water Ltd
