Any Way To Delete Use Constraints En Masse?
in Drawings
I've seen this topic raised but don't know if there is a solution. I'm sketching 'in context' and the new sketch is based off another part which creates 'use' constraints from the other sketch as the new sketch is developed. Problem is I now need to modify the new sketch and no longer need the use constraints after the sketch has been created. The next sketch will be based upon this new sketch, or another context, but the use constraints are in the way for the next step. Deleting them one by one is tedious to say the least.
Would like to 'use' a previous sketch without the 'use' constraints. Any way to do so? Or an option? Tried to copy the sketch but it copies to the origin which creates other problems to relocate in its proper location.
Any help greatly appreciated.
Thank you
Public Model below
https://cad.onshape.com/documents/e2024521ba3c9a39ae220243/w/44421595581505147108f7e2/e/53d1884b237ec15c380e55d5
If you go the copy paste route, the transform tool will snap to points, so you can project a single vertex and use it as an alignment point for the pasted sketch.
Din't know about the copy paste to a single vertex, will try that next.
