Revolute Joint Constraints Affecting Multiple Components
rex_hanson
rex_hanson Member Posts: 41 ✭✭
I am trying to model a duct network for a dust collection system. I've created models of a Wye joint and have placed it in the assembly in a couple of different locations using a revolute constraint. When I try to spin the connection at the second joint, it causes the connection at the first instance of the component to also spin.
How can I prevent this from happening?
  • mthiesmeyer
    mthiesmeyer Onshape Employees Posts: 115 image
    Hi Rex,
    Could you post a link to your doc here? It is hard to debug something like this without seeing how you have mated your parts.
    Best,
    Mike
  • rex_hanson
    Here is the link:
    https://cad.onshape.com/documents/5800daf91fc15da7b6a0a37d/w/b10fb2b6bc7a166ba9d6d17d/e/ecd06abc6ef94c0d9f142722
    If you select the last component in the model tree (Wye 6-45 <20>, then drag the rotation handle that is sticking up in the air then you will see the other pipes moving around because it appears to be impacting the other instance of the Wye 6-45 constraint.
  • rex_hanson
    I wasn't aware I could specify an angle with the fasten connector. I thought my only choices were to play with it until it selected the right mate connector orientation, and then I could apply an offset. Can I specify a rotation angle for the revolute joint connector? Thank you!
  • Tony_C_
    Tony_C_ Member Posts: 281 PRO
    Best thing to do it put a mate on there and get it about where you want it then click on it and it will show you the degree it currently positioned.  Then you can edit the mate knowing about where you want it to be.
  • Tony_C_
    Also, I think a few of those could be fasten mates or sliders.
  • rex_hanson
    Thanks! I need to learn how to use the in-context capabilities.
