How to model a screw-thread?
Steen_Winther
Member Posts: 5 ✭✭
I want to model a screw-thread and am looking for sweep with revolve (a la SW) or maybe a helix, but I can't seem to find a way. Any suggestions?
rajendra_bhat
OS Professional, Mentor Posts: 8 ✭✭
yes.. those are not available. hope onshape is getting them soon.5 -
john_mceleney
Onshape Employees Posts: 57
Steen,
Are you actually trying to model the actual thread (helix) or are you looking for cosmetic threads? In case as Rajendra commented, this will be done in the future.
John5 -
Ed_Danzer
Member, Mentor Posts: 13 ✭
Usually helix threads burn resources so I have always used a revolve for threads in SolidWorks and have never had a problem in manuals with people not knowing a threaded fastener. For large assemblies 1,000 + parts I have a configuration with the thread revolve suppressed.5
John
Cheers
FYI the best automatic thread generator I have used is on VX (or now called ZWSoft 3D).
Draw a thread profile. Choose the thread tool. Select the surface to add the thread to, choose the profile, set pitch, turns, etc, select lead in and out, root radii etc. bam. Done. Lets use that as the standard bearer.
The model is here: https://cad.onshape.com/documents/ce24e0cbec8e45c89735d148/w/c1c671cc5fc64bd69adef18e/e/d0a4b77fc2c6452db20a1c10
I then hid the shaft and supports. It can get wonky pretty quick as well but visually looks good in small displacements.
