Dimension sectioned part
Hello
It would be great to have the same dimensioning opportunities on a sectioned view. Quick fix is using a note, but still, dimension tool should be the feature. Am I doing the sectioning wrong, are there any other who have experienced the same?
    @jos_poirters Can you tell me what type of hole this is?  you should be able to dimension that just fine.  This might be best sent in as a ticket so we can take a closer look.
