Select other shortcut key on different regions / keyboard setups
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
I thought it would be helpful to collect this mystery key on separate thread.
So this is what Onshape says:
Which is actually funny as this is exactly the sound we make when searching for shortcut or cycling through available selections, öööööööööö
SELECT OTHER SHORTCUT KEY
You can now select hidden geometry by pressing a new shortcut key on your keyboard to start the Select Other command. You can keep pressing this key to cycle through the available selections, then press the left mouse button to select the highlighted geometry. This shortcut key may be different depending upon your keyboard layout, but its location will be the same (above the Tab key). For example, on a US or UK keyboard it is the Grave Accent ( ` ), on a German keyboard it is the Caret ( ^ ) and on a Spanish keyboard it is the Degree symbol ( ° ).In Finnish keyboard it seems to be ' ö '
//rami
The key above TAB does nothing, but the key labeled with:-
found up and left of the right hand shift key does invoke the "select other" function.
Cheers,
Owen S
HWM-Water Ltd
In a french azerty keyboard does anyone know the shortcut for the select other command? I've tried ² (above tab) ` (alt gr + 7) and this is not the right one.
Ok I found it, if you search it it the ù key in an azerty keyboard
Belgian keyboard I use the ù key. located right tot the letter m on belgian keyboard.
Pressing the ù key + click seems to work.
