Starting a sketch from the face of a context of another part in an assembly
john_gentilin
john_gentilin Member Posts: 15 ✭
edited November 2017 in Community Support
In this document,
https://cad.onshape.com/documents/9ec3baa19294f3198f092b39/w/26baf85d5c38ccafe4ec1fc0/e/9e352b7a38551480396b76b2
Note: Look at revision "V5" in case I move on from here.
On the Neck Assembly, I created Neck Parts as a "New Part Studio in Context". In that Part Studio, I am shooting sketches off of surfaces in the assembly. i.e. Neck Parts::Sketch5.  My question here is the volatility of that sketch. I moved the servo motor in the assembly but the sketch surface did not move with it. What it did do is make a shadow copy of the original. The same happened when I pulled the diameter from the other stepper shaft in Sketch1 using the "use" command.  I just want to verify the "use" and derive sketch from other context's are really copies of the original and are not tied to changes in that original part.
  • john_gentilin
    @NeilCooke, that's a very cool feature that it's versioned and can be updated, almost like a linked part.  Thank You.
