Resizing Sketch Made of Points
juliana_hamada224juliana_hamada224 Member Posts: 5
I recently transformed a KML file into DXF, and it came out as linked points that form a shape.
I extruded the shape from the sketch. Is there any way I can resize this shape?
Thanks a lot!
Best.
    Hi, yes indeed that's do-able.
    As ever there are a couple of ways of going about it:-
    (a) Depending on how your initial sketch is set up you may just be able to add a dimension to it to scale the whole thing.
    (b) The part "transform" tool has a uniform scale feature.
    (c) There is a non-uniform custom feature available.
    If it's still causing problems, then please post a link to your doc and I'm sure someone will help.
    Cheers,
    Owen S.
    HWM-Water Ltd
  • juliana_hamada224juliana_hamada224 Member Posts: 5
    Hi,
    Thanks a lot for your tips, owen_sparks! I could resize it as a separate part, but I'm having trouble with the other things in the sketch.
    Here's a link to it:  https://cad.onshape.com/documents/0bda087f0d92a052f66ea054/w/4b0212bfe99951ababf69dee/e/ebb563deac8883f27c51e8b3
    The idea is to make a beer cap holder with the Skaha Lake shape in the middle. I'd like to resize the lake's size to x2.6 bigger. The lake shape, name of the lake, and space for the beer caps are going to be cut out; the final board will remain as the extrusion shows.
    Any help would be great! Or suggestions on how to do it.
    Thanks a lot!
    Cheers.
    Hi @juliana_hamada224
    Here's how I would approach it:
    https://cad.onshape.com/documents/48f07de70d965faa66eac860/w/c2b94f677103016b1e0c78cd/e/2933970adbf14d90e727e41a
    1. I took the sketch as it was (and added a point near the center for step 3)
    2. I extruded the sketch away from the board as a "new" part
    3. I used the transform tool to scale the part up by 2.6x
    4. I used the transform tool to center the lake (I just did it by eye with the manipulators)
    5. I used the transform tool to push the lake solid into the board by 2mm
    6. I used the boolean tool (with 'subtract' option) to subtract the shape of the lake from the board.
    Hop this helps! Let us know if you have any questions or trouble.
    Hi @Jake_Rosenfeld!
    Thanks a lot! I was having trouble figuring it out, now I know!
    Looks great by the way.
    Cheers!
