put an assembly into the part studio?
i need to engrave the segments now that i have assembled them, how can i do this?
if i import an assembly it is a mesh, i cannot do anything with it
    Have a look at In Context Editing (ICE)
    Owen S
    HWM-Water Ltd
    edited December 2017
    Have you tried doing an in-context? This will keep the para-metic links but, the links may not be required but could be a quick workflow.
    https://cad.onshape.com/help/Content/in-context.htm
    Another option would be to export as a para-solid then re-import to a part studio. It sounds like you were exporting and importing as a stl.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 271 image
    When working with mesh data, the imported geometry can only be referenced, not modified. Can you provide a link to your document? Please be sure to share the document as public. Thank you in advance!
