Pass Boolean through FS dialog
CAD_SSP
Member Posts: 45 ✭✭
At present you cannot pass a boolean through a feature script dialog, this is ideal if you want to hide a feature in certain configurations (rather than forcing them to fail which seems an odd workaround to me).
Something like:
Something like:
<span style="background-color: transparent; color: inherit; font-size: inherit; white-space: pre-wrap;">annotation { "Name" : "My Boolean Variable" }
</span><span style="background-color: transparent; color: inherit; font-size: inherit; white-space: pre-wrap;">definition.myBooleanVariable is booleanVariable;</span>A current workaround is to pass the variable name in as a string (without "#") and then check if it is a boolean and so on but is not very intuitive as you want to include the "#" but that stops it working.
I'm not sure I understand this request. FeatureScripts can defintely use boolean inputs. They look like checkboxes.
annotation { "Name" : "My Boolean" } definition.myBoolean is boolean;0 -
@mahir what I am trying to achieve is this:
If your partstudio contains a variable that is a boolean such as "#Showitem = false" you cannot pass this boolean value into featurescript (as far as I can see).
A boolean input as you state is a checkbox, you cannot assign a variable value or a formula to it.
The only workaround I have found is to us a string query and pass the boolean name in as text, then you can use the use "getVariable" within FS to check the value i.e.<div>annotation { "Name" : "Hide If:" } definition.hideIf is string;</div>
pass in "Showitem" without the "#" and then do a check to see what if anything was passed in:<div>var hideIfcheck is boolean = false; <span>if (definition.hideIf != "") </span>{ try { if (getVariable(context, definition.hideIf)) { hideIfcheck = true; } } catch (error) { reportFeatureWarning(context, id, "you have used a non Boolean or non-existant variable"); } }</div>This is a messy workaround as you instinctively want to put the variable name when you type it with the "#" but I cannot find a way of removing that within featurescript.0 -
Have you tried isAnything? That will take a variable as input.Senior Director, Technical Services, EMEA1
isAnything(definition.myBoolean)Senior Director, Technical Services, EMEA0
A code snippet for Neil's suggestion:
annotation { "Feature Type Name" : "Take Boolean" } export const takeBoolean = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Boolean" } isAnything(definition.bool); } { if (!(definition.bool is boolean)) throw regenError("Boolean should be a boolean", ["bool"]); });
But you may want to consider just using a normal checkbox for your feature and then using configurations to toggle it rather than variables:
https://www.onshape.com/videos/introducing-onshape-configurations
Jake Rosenfeld - Modeling Team3 -
That's what I was thinking. Here's an example of configuring the Unsupressed property of a feature, which seems to be exactly what you'd like to do. In this case I used a list input to control suppression state of the circle and square, but I used checkbox inputs to independently control the suppression state of the triangle and pentagon.Jake_Rosenfeld said:
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/b02ec721136c6121c1a02cc1
2 -
Thanks, isAnything is exactly what I want.
Configurations are perfect for most applications but don't suit this particular case.0
